transmission and front end
130,000 MILES
MOONEYH
Normal driving speed drops from overdrive to drive and has to be manually downshifted and will only go into second to be able to start from a stop. When the vehicle is turned off and then started again it works normal until it does it again. I have replace both filters and fluid. Problem persists.
Also having a popping sound coming from the front end when backing, turning, and starting out, all initially and then nothing.
any help is very much appreciated. I am able to do repairs so if anyone can tell me where to start it will really help.
Apr 20, 2013 at 11:46 AM
have the trans checked for codes. it sounds electrical but a shop with a scan tool needs to see the readings
Apr 20, 2013 at 8:54 PM
