I never had any problems with the transmission until last week, but I don’t know if I have transmission issues or it’s just some sensor. Out of nowhere, after being stopped at a light then making a turn the transmission stops shifting. It started happening a week ago and since then, it’s happened three times. Two out of the three times I was at a stop light just before I started moving. The odometer moved up to 20 MPH and was going up and down while being stopped at the light. After that, when I started to move the transmission wouldn’t shift, I had to pull over put it in park and then it shifted normally again. The third time I was moving slow after being parked I made a 180 degree turn and the front right wheel felt like it was going over bumps into the turn, after getting out of the turn the transmission wouldn’t shift until I put it in park and then re engaged. Any ideas?
Mar 31, 2022 at 7:39 PM
