Transmission
168,000 MILES • 6 CYL • 2WD • AUTOMATIC
WILLIAM WHITNEY
Transmission slams in first few gears then will not go in overdrive. No check engine light but transmission light flashes.
Aug 10, 2017 at 6:39 AM
  • 55,766 POSTS
It sounds like you have a one of two problems, the first will be a plugged catalytic converter which will cause the vacuum of the engine to be low and make the transmission shift late and not go into overdrive.
Here is a test that will confirm the problem,
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
The other would be a MAF sensor that is off. I would try cleaning the sensor first. Here is a guide for that as well.
https://www.2carpros.com/articles/mass-air-flow-service
This will cause the readings to the computer to be off and cause the same problem.
Cheers, Ken
Aug 14, 2017 at 2:13 AM
WILLIAM WHITNEY
Thanks, I will give both of them a try!!
Aug 14, 2017 at 9:02 AM
WILLIAM WHITNEY
Cleaning the MAF didn't work will try the cat next .
Aug 15, 2017 at 6:32 AM
  • 55,766 POSTS
Okay, that will cause the problem. Let me know
Aug 16, 2017 at 3:28 AM
