Transmission only goes in reverse
225,000 MILES • 4.9L • V6 • 2WD • AUTOMATIC
PTHACKER
  • 5 POSTS
I just put a new transmission on my truck because it would only drive in reverse. once replaced I still have the same problem it; only wants to go in reverse, but if I put in drive and rev real hard once I let off the gas it will jump forward a little bit. what is my problem?
Oct 11, 2019 at 5:21 AM
Good afternoon,
Is this a used transmission?
Are there any codes stored?
Mar 24, 2021 at 5:00 AM
PTHACKER
  • 5 POSTS
Yes, it's used got it from pull-a-part. don't know about the codes, can't check.
Okay, either the replacement is bad or it could be fluid.
Did you change the fluid and filter?
Is the check engine light on?
PTHACKER
  • 5 POSTS
So I do not know about this one, but when the drive shaft was on the ground I rolled it and heard a little bit of a clunking noise. could that be the problem?
No, that would not prevent it from going into forward.
PTHACKER
  • 5 POSTS
Okay, so what are all my possible problems?
Most likely internal in the transmission. It will have to be removed and torn down to find the failure.
PTHACKER
  • 5 POSTS
Okay, thanks.
You are welcome.
Always glad to help.
