Transmission will not into gear
175,000 MILES • 5.9L • V8 • 4WD
RYAN LARSON
It will start and run. Will not go into any gear. The hear selector moves but the vehicle doesn't move at all. it's like it's in park the entire time no matter what gear you choose.
Mar 4, 2019 at 12:25 PM
Good morning,
If you shift it into neutral, does it roll freely? Want to be sure it is not the shift cable that is causing this issue.
Also, when was the last time you changed your oil and filter in the transmission?
Mar 4, 2019 at 7:21 PM
