Driving down road fine and then lost all gears. Only makes a winning sound.
Sep 26, 2018 at 7:08 AM
DANNY L
✓Experienced Mechanic
Hello,I am Danny.
By any chance when this happened did the Check Engine Light come on? Hopefully a transmission code is stored and that can help the diagnostic process. If you do not have access to a code reader your local auto parts stores have a tool loaner and can rent you one. I have attached a tutorial showing what's involved. Also, was the transmission serviced regularly? Hope this helps and thanks for using 2CarPros.
Danny-
