transmission
10,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
LORRI HILLHOUSE
Car is not pulling in drive. there is no dipstick. how do you check fluid and add it?
Dec 18, 2017 at 1:48 AM
CJ MEDEVAC
  • 11,000 POSTS
I am going to hook you up with a video that might help.
The person in the video identifies the plug you remove as not to overfill. The fluid should barely run out of the hole (under the car on the transmission) when it is full.
He will also identify the fill hole.
https://www.youtube.com/watch?v=U1NAn6rTPLE
Basically, fill it till it barely runs out of the other hole.
Any questions?
I looked in our "repair guides", which is found at the top right side of our pages, I was not able to find your specific procedure. However, before you leave us, Look through the many items that "repair guides" offers, you may find something useful and enlightening for other services to your car.
Let us know how things go!
The Medic
Dec 18, 2017 at 10:02 AM
LORRI HILLHOUSE
Thank you. It turns out that it is the passing gear cable slipping off.
Dec 19, 2017 at 1:57 AM
CJ MEDEVAC
  • 11,000 POSTS
Glad you got it all figgered out!
Before you drive away into the sunset, save us on your GPS!
Go to the top of any page and click onto "Repair Guides",
Lots of stuff in there that might help you later.
Merry Christmas!
The Medic
Dec 19, 2017 at 12:29 PM
