Code p1750
180,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
ANTHONY SWINDLE
Where is the transmission solenoid assembly? I have the p1750 code on my car. Rev do not work and it is hard to get it to shift past second gear.
Apr 5, 2018 at 9:14 AM
Good evening.
Can you verify the engine size and the code? I see no 2.4 or p1750.
Apr 5, 2018 at 10:33 AM
ANTHONY SWINDLE
The engine size is a 2.4. And the code is p1750. it is talking about the transmission solenoid assembly .
Apr 5, 2018 at 11:26 PM
  • 55,770 POSTS
First make sure the transmission is full and has a clean filter which can effect the pressure.
Below is a guide showing the solenoid valve and their locations. Number three is the one you want to replace.
Check out the diagrams (below).
Please let us know what you find.
Cheers, Ken
Apr 6, 2018 at 4:48 AM
