Transmission fluid leaking
139,843 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BRADLEY40OZ2FREE
I have a small leak and it’s transmission fluid. It looks like it’s coming from the middle front behind the belts. Is there a drain plug for the transmission?
Nov 13, 2019 at 1:11 AM
Good afternoon,
If you have transmission fluid leaking by the belt area, it most likely is coming from a leaking cooler line from the transmission.
I attached a picture for you to view of the location.
No, there is no drain plug for the fluid. The pan has to be dropped to remove the fluid.
Apr 9, 2021 at 12:47 PM
