Transmission
238,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
JONCRE
Wont down shift from drive
Have to manual shift to low
to take off then to drive
every time i stop .
Mar 5, 2016 at 7:56 PM
HMAC300
  • 48,601 POSTS
have a trans guy scan this it may be a wiring issue or an internal one on trans.
Mar 6, 2016 at 12:10 AM
JONCRE
All i did was change the fluid & fiter
Mar 6, 2016 at 2:36 AM
HMAC300
  • 48,601 POSTS
then recheck your work like make sure the seal is in at the filter and not sucking air. if there was an old oring in filter at valve body remove it and reinstall filter. it may not be totally full either.
Mar 6, 2016 at 2:57 AM
