Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Drivetrain
Transmission
Reverse
Transmission only goes in reverse
1995 TOYOTA CAMRY
220,000 MILES • 1.9L • 6 CYL • 2WD • AUTOMATIC
GARY SALERNO
MEMBER
1 POST
Goes into reverse one day, park it now no forward before only reverse.
Feb 15, 2019 at 12:06 PM
Experienced Mechanic
Good morning,
Sounds like you may have an internal issue with the transmission.
I would start by changing the oil/filter in the transmission. It may have a clogged filter.
If that does not help, the transmission will have to be removed and inspected for the failure.
Feb 15, 2019 at 7:23 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
