Clutch adjustment on transmission instructions needed
198,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
SNOWMONKEY691
How to adjust my clutch on my transmission of my truck listed above? It is hydraulic.. I already bled the system but i can still barely get into first gear? Any help?
Jun 10, 2020 at 11:07 AM
  • 55,711 POSTS
These clutches are self adjusting. do you have good pedal? if so it could be the clutch disc is fallen apart not allowing the clutch to become disengaged. Here is a guide to help and a video that will walk you through the clutch job on a similar car:
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
and
https://youtu.be/JpzefqEeVGE
Can you please shoot a quick video with your phone so we can see what's going on? that would be great. You can upload it here with your response. Please run down these guides and report back.
Mar 24, 2021 at 5:21 AM
SNOWMONKEY691
I have to align the gear with second then almost slam the lever into first to pop it into gear.
  • 55,711 POSTS
Yep, its either the clutch disc or pilot bearing is out, either way the transmission needs to come out and the clutch replaced/inspected.
