Transmission
160,000 MILES • 3.6L • V6 • AUTOMATIC
LAWRENCEMOLINA
When you use a pump do you have to keep the car running when filling the transmission with fluid?
Mar 11, 2017 at 7:00 AM
  • 31,937 POSTS
The engine should be running and the transmission in Park, the transmission oil must be between 30-50deg C and the oil must only trickle out of the filler plug, the oil used is Dex 111 the oil temperature is critical for accurate filling. this is checked with a scanner that has PIDs for transmission temperature reading.
Mar 11, 2017 at 8:34 AM
