You should have the 4L60/65 or 80/85 E transmission. You can swap in any other E transmission but if it is out of a different body style then you may have some wiring alterations to make but it should fit with no issue.
Here is a video that will help with this:
https://www.youtube.com/watch?v=3vJAojsrfuU
Below you will find the process from the manual that will help with this the replacement.
Let us know if you have other questions. Thanks
Images (Click to enlarge)
May 7, 2021 at 1:50 AM
