Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Buick
Rendezvous
Drivetrain
Transmission
Filter
Replace/Remove
Transmission filter has metal and brass shavings in it
2005 BUICK RENDEZVOUS
200,564 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
DUSTYAE
MEMBER
I change the transmission filter. I took the filter apart and they got metal and brass shavings in it.
Sep 24, 2019 at 12:15 AM
Experienced Mechanic
Good morning,
Got metal and filings where?
Did it come out of the old filter?
Sep 24, 2019 at 1:26 AM
DUSTYAE
MEMBER
That metal and brass pieces I came out the old transmission oil filter I took it apart to see what was inside.
Sep 24, 2019 at 1:36 AM
Okay, that is not a good sign at all. That tells me there is damage inside the transmission.
Do you have any issues with the transmission?
Sep 24, 2019 at 1:39 AM
DUSTYAE
MEMBER
Started slipping anyone going to gear.
Image (Click to enlarge)
Sep 24, 2019 at 1:40 AM
It sounds like it is going to need to be rebuilt. The metal and brass are clutch material.
It may help with a new filter but the end is near for the transmission.
Sep 24, 2019 at 1:44 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
