try to clean it up to see where it is leaking if near torque converter .have a transmission shop fix it. if anything else a mechanic can do it.
Mar 14, 2017 at 11:53 PM
YKIDA
MEMBER
Okay, thanks!
Mar 15, 2017 at 8:01 AM
✓Experienced Mechanic
Try to keep fluid in it so it doesn't run low as well before you can have it fixed, you might be able to tighten the where the leak is coming from such as a cooler line or gasket.
Best, Ken
Mar 18, 2017 at 1:14 AM
YKIDA
MEMBER
OK. I got that problem fix with the transmission fluid leak. Now the car check engine light come on breakdown the speed while driving emission come on then that when the speed break down
Apr 4, 2017 at 10:23 AM
What was the leak, also if you have a new problem please start a new question.
