If it does not move in all gears, either forward or reverse, it could be due to low fluid level, faulty transmission or a broken drive axle. Try checking the transmission fluid level first.
Nov 17, 2017 at 11:06 PM
FERNANDO MARTINEZ
MEMBER
In reverse work no problem. only D, 1, 2.
Nov 17, 2017 at 11:50 PM
FERNANDO MARTINEZ
MEMBER
I drive normal and i see the rpm and speed no match rpm is too high i stop and after no drive gears only reverse. i change oil and filter no metal residue.
Nov 18, 2017 at 12:01 PM
KHLOW2008
✓Experienced Mechanic
Did you check the transmission fluid level before replacing it?
What was the color of the fluid and was there any burnt smell?
Symptom indicates a fault within the transmission and most probably you would need a rebuilt.
