transmission
200,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
JOSHM009
Hard shift from park to reverse. Them want s*** from first to any other gear. When it tries to shift stalls out.
Feb 28, 2016 at 11:16 PM
JOSHM009
It threw a 02 code changed 02 sensor. Now no code but still having the same problem. How do I get it to throw a code?
Feb 28, 2016 at 11:22 PM
HMAC300
  • 48,601 POSTS
just have a trans guy scan for codes it may not be an engine / trans code but causing problem check all fuses under hood as well
Feb 28, 2016 at 11:23 PM
JOSHM009
Can you scan a transmission with a regular scan tool u buy from auto parts store?
Feb 28, 2016 at 11:25 PM
HMAC300
  • 48,601 POSTS
yes but it may be fused or there iwiring issue and the connector isn't getting power so it can be read, besides if it's an internal problem maybe it can be fixed
Feb 28, 2016 at 11:49 PM
