Do I need to replace the transmission filter after replacing the transmission fluid?
200,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
NOLTHABOUL
I recently did a transmission fluid drain and refill, I was wondering if a new transmission filter was necessary if they 1.3 hybrids even come with them?
Jul 17, 2022 at 11:43 AM
SQM
  • 6,383 POSTS
There is a filter for the CVT, located inside of a housing on the upper side of the transmission. You will have to remove the battery to access it.
Interestingly the standard fluid change does not require changing of the filter. However, it is a good idea to replace it.
You will need 3.1 quarts of ATF-Z1 transmission fluid.
Here is a helpful video on how to change the filter:
https://youtu.be/hs8tFhOtrYc
Let me know of any questions.
Jul 17, 2022 at 1:21 PM
