Truck has gone through five transmissions in just 24,000 miles
64,000 MILES • 2.7L • V8 • 4WD • AUTOMATIC
STEVE63!
  • 6 POSTS
when i bought this truck it had 40,000 now it has 64,000 and it's going on it's fifth transmission. i don't tow or anything with this truck, truly regret getting a Chevrolet have always been a Ford man. any suggestions? i have heard maybe a software update, not sure anymore.
Jun 23, 2019 at 11:17 PM
Good afternoon,
Did you replace the transmissions with new or used?
What were the issues with the transmissions?
Jun 24, 2019 at 6:15 AM
STEVE63!
  • 6 POSTS
Rebuild the the first time then new and bigger.
Jun 24, 2019 at 7:15 AM
Okay, what about the other times?
Did you have the TCM flashed?
Are there any codes?
Jun 24, 2019 at 7:17 AM
STEVE63!
  • 6 POSTS
New, and they put a bigger cooler in, as well. No that's the strange thing, a code came up to replace the gas cap but my mechanic found the shavings in the fluid again so back to the transmission shop.
Jun 24, 2019 at 8:10 AM
STEVE63!
  • 6 POSTS
Someone said maybe it needs a software update? Have you ever heard of that?
Jun 24, 2019 at 8:11 AM
Okay, sounds like you need to have the lines flushed out. If they did not flush the cooler correctly, the metal will get into the replacement transmission.
Jun 24, 2019 at 8:13 AM
STEVE63!
  • 6 POSTS
Thank you so much, I'm bringing it back tomorrow.
Jun 24, 2019 at 8:19 AM
You are welcome.
Keep us updated.
Jun 24, 2019 at 8:24 AM
STEVE63!
  • 6 POSTS
I will. thank you so much.
Jun 24, 2019 at 8:26 AM
You are welcome.
Jun 25, 2019 at 7:40 PM
