Truck has gone through five transmissions in just 24,000 miles
2007 CHEVROLET 2500
64,000 MILES • 2.7L • V8 • 4WD • AUTOMATIC
STEVE63!
  • 6 POSTS
when i bought this truck it had 40,000 now it has 64,000 and it's going on it's fifth transmission. i don't tow or anything with this truck, truly regret getting a Chevrolet have always been a Ford man. any suggestions? i have heard maybe a software update, not sure anymore.
Jun 24, 2019 at 6:17 AM
  • CAR REPAIR CONTRIBUTOR
Good afternoon,
Did you replace the transmissions with new or used?
What were the issues with the transmissions?
Jun 24, 2019 at 1:15 PM
STEVE63!
  • 6 POSTS
Rebuild the the first time then new and bigger.
Jun 24, 2019 at 2:15 PM
Okay, what about the other times?
Did you have the TCM flashed?
Are there any codes?
Jun 24, 2019 at 2:17 PM
STEVE63!
  • 6 POSTS
New, and they put a bigger cooler in, as well. No that's the strange thing, a code came up to replace the gas cap but my mechanic found the shavings in the fluid again so back to the transmission shop.
Jun 24, 2019 at 3:10 PM
STEVE63!
  • 6 POSTS
Someone said maybe it needs a software update? Have you ever heard of that?
Jun 24, 2019 at 3:11 PM
Okay, sounds like you need to have the lines flushed out. If they did not flush the cooler correctly, the metal will get into the replacement transmission.
Jun 24, 2019 at 3:13 PM
STEVE63!
  • 6 POSTS
Thank you so much, I'm bringing it back tomorrow.
Jun 24, 2019 at 3:19 PM
You are welcome.
Keep us updated.
Jun 24, 2019 at 3:24 PM
STEVE63!
  • 6 POSTS
I will. thank you so much.
Jun 24, 2019 at 3:26 PM
You are welcome.
Jun 26, 2019 at 2:40 AM
