My truck misses second gear. Does not slip or grind. I can manually put it in second and it will go. It goes from first to third and up from there.
Apr 2, 2018 at 8:49 AM
✓Experienced Mechanic
Good morning.
Is the check engine light on?
Also, if you can manually shift it to second gear, it sounds like a valve body issue. if there is no code for the 1-2 shift solenoid then that is not the issue. it would be mechanical in the valve body.
