Transmission will not shift into second gear
171,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
MATTALFORD
My truck misses second gear. Does not slip or grind. I can manually put it in second and it will go. It goes from first to third and up from there.
Apr 2, 2018 at 8:49 AM
Good morning.
Is the check engine light on?
Also, if you can manually shift it to second gear, it sounds like a valve body issue. if there is no code for the 1-2 shift solenoid then that is not the issue. it would be mechanical in the valve body.
Apr 2, 2018 at 9:38 PM
