Transmission shifting hard?
296,000 MILES • 4.9L • 6 CYL • 2WD • AUTOMATIC
CHARLES GODWIN JR.
  • 9 POSTS
My transmission is shifting very hard. I have already serviced it. I have been told it could be the shift solenoid. Wondering what you thought.
Feb 25, 2019 at 7:46 AM
Good evening,
Yes, it could be a solenoid but before I would say yes, I would change the oil/filter in the transmission to be sure dirt is not restricting the valve in the valve body.
Mar 24, 2021 at 6:50 AM
CHARLES GODWIN JR.
  • 9 POSTS
Can you give me an idea where it is located on my transmission?
I need to know which transmission you have.
Is it a C6 or E4OD?
There should be a tag on the side.
CHARLES GODWIN JR.
  • 9 POSTS
I believe it is the e40d.
They do not show any pictures of the solenoids but they are on the valve body. There are two shift solenoids and a torque converter solenoid.
You could try changing them but I doubt it will help.
CHARLES GODWIN JR.
  • 9 POSTS
So if that doesn't work what then?
Mar 24, 2021 at 6:51 AM
Then the transmission will have to be removed and disassembled for inspection.
CHARLES GODWIN JR.
  • 9 POSTS
Okay, thanks for the help.
You're welcome.
Always glad to help.
CHARLES GODWIN JR.
  • 9 POSTS
What would give my truck a rough idle and hesitate on take off?
Engine misfire.
CHARLES GODWIN JR.
  • 9 POSTS
What would make my truck idle up an down then fine the next minute.
Idle air control valve.
CHARLES GODWIN JR.
  • 9 POSTS
Thanks.
You are welcome.
Glad to help.
