I recently had two new front tires put on. The tires were the wrong size - different than the back two. After they were put on the 4wd! light came on and it felt like the vehicle had trouble changing gears. When the tires were replaced with the correct size, the light no longer comes on, but it still feels like it is having trouble changing gears. The 4wd has to be manually put on normally, so I'm not sure if this has affected the transmission or not.
May 11, 2021 at 1:25 AM
