Transmission after it warms up a check engine light turns on and it will not shift out of first gear?
98,523 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
AK5252012
My vehicle listed above will start up and drive but after it warms up, I'll get a check engine light, and it won't shift out of first gear. then when I stop it won't go into reverse.
Also, when I shut it off and let it sit it will reset. Then I can drive it, and it shifts fine but keep repeating the same thing. Once it warms up boom it won't shift.
Nov 29, 2024 at 10:46 AM
  • 110,248 POSTS
When the light is on, have the computer scanned for diagnostic trouble codes. That is the best way to determine which direction to go.
Here is a link showing what I am referring to:
Let me know if that is something you can do or have done.
joe
Nov 29, 2024 at 11:37 AM
