Transmission does not engage drive?
162,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
AARONSMURF
Transmission will shift smoothly into reverse and neutral but will not engage drive. No jerking, no change in RPM from N to D. Happened suddenly, only symptom was it jerked into Drive 1 time before it happened.
Nov 26, 2022 at 9:53 AM
  • 110,246 POSTS
The idea that it hit first hard and then this happened leads me to think there is an issue with the transmission line pressure. By any chance, does the check engine light stay on when the engine is running? If it does, I recommend having the computers scanned for diagnostic trouble codes.
Here is a link that explains how it's done:
Next, there were problems with the transmission cooler getting plugged and restricting line pressure. Has the transmission ever been serviced? If it was, was the cooler flushed?
Take a look at the service bulletin below.
Let me know your thoughts and as much info as you can think of. For example, is the fluid clean, full, and without a burnt smell?
See pic below.
Nov 27, 2022 at 3:04 PM
