The transmission is stuck in neutral and will not engage gears?
310,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
VORTEX555
  • 10 POSTS
My vehicle listed above is stuck in neutral and won't engage gear shifts.
Oct 24, 2023 at 7:24 AM
  • 110,251 POSTS
Did this happen all at once? When you shift the gears, does the gear indicator show the correct gear?
Do me a favor. On the side of the transmission (driver's side) is the shift linkage which attaches to a manual lever on the transmission. Check to see if it is disconnected or if the bracket is damaged.
I attached a picture below showing what to look for. If it appears to be okay, with the vehicle safely secured and the parking brake applied, have a helper shift through the gears while you watch to see if the lever is moving.
See pic below.
Oct 24, 2023 at 10:49 AM
VORTEX555
  • 10 POSTS
The link is fine. It all started after I let my brother drive it, he brought it back and in the morning, I was going to take the wife to work. I noticed it was in drive and off. So, I put the key to just power and shifted into park and then started it up. What I didn't notice was it was in 4low. I jumped onto the highway did about 50 noticed the switch put back in 4awd and continued. Then it started kind of jerking and then wouldn't respond to the gas pedal. So, I pulled over and did the usual but nothing no drive or reverse. And when I shifted from drive to park it made a weird whining noise and clicking. The engine starts in any gear I think and purs but the speedometer goes up to like 40 and then settles.
Oct 24, 2023 at 11:26 AM
  • 110,251 POSTS
It sounds like it is related to the transfer case. Try this. Start the engine and place the vehicle in neutral. Shift the transfer case back to low and then to a normal mode.
I know what happened. The transfer case isn't shifting and is between gears. That is why it feels like it is in neutral. It isn't engaged. It is in neutral and not the transmission. When you shift to park, the noise you hear is the parking paw trying to grab.
Oct 24, 2023 at 12:03 PM
VORTEX555
  • 10 POSTS
I did nothing happened, well there's a noise like it's trying to do something but nothing happens.
Oct 24, 2023 at 12:13 PM
  • 110,251 POSTS
We may need to remove the transfer case shift motor. However, I have a question. Were you driving it at 50 mph in low lock? Also, when you try to shift it, is the sound coming from the transfer case or some other area?
If you were in low range at 50 mph on dry pavement, something internal in the transfer case may have been damaged.
Oct 24, 2023 at 12:20 PM
VORTEX555
  • 10 POSTS
I know you're not supposed go that fast in 4low but it was too late when I noticed. The sounds coming from the driver's side kind of under the seat and in the engine bay driver side. I was curious about that, the transfer case shift motor.
Oct 24, 2023 at 12:37 PM
  • 110,251 POSTS
That is my first suspect. Is it possible for you to record the noise and upload it for me to hear?
Oct 24, 2023 at 12:45 PM
VORTEX555
  • 10 POSTS
Yes, it is possible hold on.
Oct 24, 2023 at 12:46 PM
VORTEX555
  • 10 POSTS
Here.
Oct 24, 2023 at 1:05 PM
  • 110,251 POSTS
Wow, I certainly heard that. I feel it would be a good idea to remove the shift motor on the transfer case. If nothing is broken such as a u-joint, axle joint or anything external, I suspect the problem is internal. It could be the drive chain that is damaged.
First, check the fluid to see if there is anything metallic mixed with the fluid. You may want to drain it, but that is up to you.
If the fluid is clean and full, remove the shift motor for inspection. Also, if you haven't already, just make sure nothing is damaged with any of the axle joints/driveshaft. The idea of the speedometer moving indicates the transmission is working. Also, make sure to check the fluid in the front differential. Something has come apart.
Oct 24, 2023 at 1:29 PM
VORTEX555
  • 10 POSTS
Awesomeness, thanks Joe! Yes, finally some understanding:) I'll definitely check all that, those make sense, is the drive chain like the belt between the transmission and engine?
Oct 24, 2023 at 1:50 PM
  • 55,782 POSTS
Can I ask if the driveshaft is spinning when in gear? If so, you have a broken axle in the rear differential.
Oct 25, 2023 at 1:36 AM
VORTEX555
  • 10 POSTS
Reply to Joe.
I didn't understand at first but this image you included looks just like that except for it protruded out and doesn't move. I noticed it because everything is full of dirt and grime and it was the only clean shiny thing around.
Oct 25, 2023 at 2:40 AM
VORTEX555
  • 10 POSTS
Reply to Ken,
No it is not spinning.
Oct 25, 2023 at 2:41 AM
  • 110,251 POSTS
If you see the shift lever, clean around it to see if something has broken or become detached. Also, make sure the mount that the cable is attached to is also in good condition.
If the lever isn't moving, disconnect the cable and move the lever by hand to see if it goes into gear or park. Please be careful when under the vehicle. Also, rather than placing it in gear, with the engine off and the parking brake on, see if you can get it in park. If you can, then the cable is the issue.
The only thing is that doesn't explain the speedo moving. Regardless, check to see if it is damaged and attached.
Oct 25, 2023 at 11:23 AM
VORTEX555
  • 10 POSTS
How do I remove it? It's like extremely difficult to get to. The drive shaft is in the way. And where does it go from the transmission?
Oct 26, 2023 at 12:58 AM
  • 55,782 POSTS
The fact that the speedometer works tells us the output shaft of the transmission is spinning. If the drive shafts are not turning, then something has broken inside the transfer case. I would remove it and disassemble to see what happened, here is how. Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Oct 26, 2023 at 5:17 AM
