Transmission fluid level
205,450 MILES • 3.8L • V6 • 2WD • AUTOMATIC
ARDIS WRIGHT
I changed my transmission filter and put four quarts to begin with. Then cranked it and put my foot on the brake. Then checked it again to see if I had to add more it didn't read but a drop on the stick so I added one and a half more quarts and it's still barely reading on the stick. but it reads almost full when it's not cranked and cold.
Nov 20, 2019 at 6:26 AM
Good afternoon,
When you change the pan and the filter it takes about 7 quarts to fill the system. Check the level on level ground with the engine warm and the car in park. Let me know the level. Roy
Mar 17, 2021 at 8:50 AM
ARDIS WRIGHT
I addedore to make it a total of 7 quarts. It's reading right now. I drove it and it seams okay for now. Thanks
You are welcome.
Always glad to help.
