Transmission swap
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DIRTYRED38
Can you put a 5.7 Hemi NAG1 transmission in a 3.5 5 speed engine?
Dec 12, 2018 at 1:06 AM
Good afternoon,
The transmission was an option for the 3.5 motor. So the simple answer is yes.
In order to perform this you will need to get a wire harness and most likely the PCM which has the TCM inside it. You will need the correct PCM and have it programmed to the car.
Dec 12, 2018 at 3:47 AM
DIRTYRED38
So the PCM has to be from a 3.5 or 5.7? And the wiring harness is the engine wiring harness?
Dec 12, 2018 at 1:37 PM
The harness has to be from a 3.5 with the trans you are using.
Yes. That is part of the engine harness.
Dec 12, 2018 at 7:54 PM
