car revved
179,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
UP29BALNE1
  • 65 POSTS
Started the car the other day and went to pull away from the house and when stepping on the accelerator the car did not respond and the rpms just revved up. I checked the fluid level by pulling the drain plug. Can you direct me where to start looking for a solution? I was thinking solenoid or fuse. All help appreciated.
Nov 19, 2017 at 1:43 AM
JIS001
  • 3,412 POSTS
Given the mileage on the vehicle, it looks like you will need to have the transmission rebuilt.
Nov 19, 2017 at 6:56 AM
UP29BALNE1
  • 65 POSTS
No chance of it being a solenoid inside of the transmission? It does not have any gear. I have never had any problems with the transmission slipping or stalling, not one hiccup.
Nov 19, 2017 at 9:41 AM
JIS001
  • 3,412 POSTS
If there is a fault in the valve body then the check engine light would come on setting a code. If a solenoid is jammed, most likely it is because some material from the transmission may have gotten into it like worn clutch material or metal shavings. That would be an indicator for a transmission overhaul. A transmission shop can do a stall test hooking up a pressure tester to check for pressure but ultimately a tear down is required to find the point of failure.
Also, you mentioned early you pull a plug to check it? If there is no dipstick, did the fluid come out as a slow drip from the plug? You can also remove the pan to inspect for debris. If full of clutch material or metal, then you will need a tear down.
Also, what color was the fluid?
Fluid condition check:
Observe the color and the odor of the fluid. Under normal circumstances, the color should be dark reddish, not brown or black.
Allow the fluid to drip onto a facial tissue and examine the stain.
If evidence of solid material is found, the transmission fluid pan should be removed for further inspection.
If fluid contamination or transmission failure is confirmed by the sediment in the bottom of the transmission fluid pan, the transmission must be disassembled and completely cleaned.
Nov 19, 2017 at 9:59 AM
UP29BALNE1
  • 65 POSTS
The fluid barely came out when I undid the allen in the middle of the drain plug. I had the car on jack stands level when I checked it. I will check computer codes with my code reader and take a look and see if the check engine light is on or any other warning indicators and then go back under the car and check the color on the tissue and look for sediment, shavings or any other material and probably either way just pull the pan and get back to you on my findings tomorrow.
Nov 19, 2017 at 10:26 AM
UP29BALNE1
  • 65 POSTS
Okay no codes came up on the scan tool. Pulled the pan and the color was dark reddish, looked and smelled perfect, absolutely zero metal in the pan except for a huge piece of one of the bands. I think I found the problem. Now when I order the rebuild kit some say without bands some say complete kit but there is no filter so how the hell do they think that's a master rebuild kit if it doesn't have a filter. Thanks for all your help maybe you know where to buy the kit online. thanks again.
Nov 21, 2017 at 7:32 PM
  • 55,721 POSTS
Do me a favor, can you check the CV axles becasue if one is broken at the CV joint which happens the car will seem like its in neutral in every gear. While in gear one of the axles will be turning but not going anywhere.
Cheers, Ken
Nov 24, 2017 at 10:42 AM
UP29BALNE1
  • 65 POSTS
I will check that and get back to you tomorrow
Nov 24, 2017 at 12:49 PM
  • 55,721 POSTS
Cheers, Ken
Nov 26, 2017 at 4:39 AM
