Codes P0746, P2714, and P2808, after driving for 10 minutes it goes into limp mode?
12,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
ANI SWAGZ EZEKIEL KIEL
  • 5 POSTS
The car drivers when at the first start up but after 10 minutes it goes into limp mode.
P0746
P2714
P2808
Above is the code it shows.
Valvebody has been changed, converter too has been changed the seals are good.
Aug 5, 2024 at 10:56 PM
  • 5 POSTS
The Reverse is good.
Aug 5, 2024 at 10:58 PM
  • 5 POSTS
The wiring connection to control module is all good too.
Aug 5, 2024 at 10:59 PM
  • 110,248 POSTS
All of the codes are related to the transmission pressure control system. When you drive the vehicle, have you ever noticed a slipping when it shifts?
Also, is the transmission fluid clean and full?
Let me know. Also, let me know if the vehicle only has 12,000 miles.
Aug 7, 2024 at 5:34 AM
  • 5 POSTS
I meant 120,000. The transmission oil is dark brown, but I doubt if it is full. I added a total of 7 liters of oil.
Aug 9, 2024 at 3:11 PM
  • 5 POSTS
Yes, the car slips.
Aug 9, 2024 at 3:12 PM
  • 110,248 POSTS
If the transmission was dry, totally empty of fluid, it only holds 6.5 liters. You must have it overfull.
Take a look at the directions below. Let me know if that is how you checked level. Also, let me know what type of transmission fluid was used.
See pic below.
Aug 10, 2024 at 11:26 AM
