Transmission
179,000 MILES • V6 • 2WD • AUTOMATIC
HEATHER MASSEL WHITTLE
After stopping and then going, the revs go up and it is slow to go for three seconds or so and then kicks in. When this happens the DRNL2L1 light indicators do not light up as well as the automatic locks do not work when turning off vehicle. Last night I went out and it was fine.
Oct 5, 2018 at 11:24 PM
Good morning.
The first thing I would do is clean the battery cables real well.
Low voltage will cause this issue and power comes from the battery.
Are there any codes stored?
Oct 6, 2018 at 11:11 PM
Hi Roy, my son is coming over today to read the codes. I went into town yesterday and it would do the same thing but when I turn the car off and on again it is fine. Hmm, not even a full moon, lol. I will send another message after I get the code or codes. Thank you for your reply.
Oct 7, 2018 at 12:22 AM
You are welcome.
Will be here all day.
Oct 7, 2018 at 12:27 AM
U0073 control bus off and P0700.
Oct 7, 2018 at 3:42 AM
Okay, the 73 code is a serial data line code. In other words, there is no communication between modules. It looks like the issue is with the transmission control module. It could be just a connector needing to be cleaned or it may be the module itself.
The 700 code is a general code for a transmission fault. There is usually another code along with this code.
DTC U0073
DTC Descriptors
DTC U0073 00: High Speed Communication Bus.
DTC U0073 71: Control Module Communication Bus Off Invalid.
DTC U0073 72: Control Module Communication Bus Off Alive Counter Incorrect.
Circuit/System Description
The high speed GMLAN serial data circuits are high speed serial data buses used to communicate information between the control modules. Typical data transmission speeds must be high enough to ensure that a required real-time response is maintained. The high speed GMLAN serial data circuits also connect directly to the data link connector (DLC).
Conditions for Running the DTC
- Supply voltage to the modules are in the normal operating range.
- The vehicle power mode requires serial data communications.
Conditions for Setting the DTC
The module setting the DTC has attempted to establish communications on the GMLAN circuits more than 3 times.
Action Taken When the DTC Sets
- The module suspends all message transmission.
- The module uses default values for all parameters received on the serial data circuits.
- The module inhibits the setting of all other communication DTCs.
Conditions for Clearing the DTC
- A current DTC clears when the malfunction is no longer present.
- A history DTC clears when the module ignition cycle counter reaches the reset threshold of 50, without a repeat of the malfunction.
Diagnostic Aids
- An intermittent condition is likely to be caused by a short on the high speed GMLAN serial data circuits.
- This DTC cannot be retrieved with a current status. Diagnosis is accomplished using the symptom Scan Tool Does Not Communicate with High Speed GMLAN Device.
- Refer to Data Link References for the specific modules using high speed GMLAN serial data.
Oct 7, 2018 at 4:09 AM
