No codes and the transmission was starting to slip.
Sep 28, 2019 at 7:34 AM
✓Experienced Mechanic
Okay. that is not the valve body at all. Slipping is internal with the clutches and seals. That is a mechanical issue and there are no codes for mechanical issues.
Sounds like you need to rebuild or replace the transmission.
Sep 28, 2019 at 7:57 AM
LAWRENCE CHENOWETH
MEMBER
What is the thing called that has four bolts before you take off the valve body it has a round big spring in it does it push on a clutch?
Sep 28, 2019 at 7:59 AM
Can you post a picture?
It sounds like an accumulator spring. That is a spring that applies a band for smooth operation.
Sep 28, 2019 at 8:02 AM
LAWRENCE CHENOWETH
MEMBER
I wasn't having this problem before it was slipping but not this bad. Plus it engaged into gear and moved now it en-gauges but when go to move it slips out of gear.
Sep 28, 2019 at 8:04 AM
Okay, then something happened during your repair replacing the valve body.
You need to go over your work.
Did you replace the gaskets when you changed the valve body?
Sep 28, 2019 at 8:13 AM
LAWRENCE CHENOWETH
MEMBER
Yes, the new valve body came with the new gasket on it and the shift solenoid is new as well. I bought them as a pair .
Sep 28, 2019 at 8:22 AM
Okay, something is not correct as it is not the same as it was prior to the repair.
Was the valve body identical?
Sep 28, 2019 at 8:33 AM
LAWRENCE CHENOWETH
MEMBER
They looked the same to me. the plug only plugs in one way doesn't it?
Sep 28, 2019 at 8:43 AM
Okay, something is incorrect. You need to start from scratch and pull it down again.
Sep 28, 2019 at 8:48 AM
LAWRENCE CHENOWETH
MEMBER
Okay, I don't know what it could be other than the spring thing that band didn't look right. The band under it moves around not sure.
Sep 28, 2019 at 8:51 AM
Was the spring broken?
Sep 28, 2019 at 8:56 AM
LAWRENCE CHENOWETH
MEMBER
No, that is why I don't understand what went wrong the transmission fluid looked brown but no metal shavings on the magnetic. There was a bunch of sludge though.
Sep 28, 2019 at 9:01 AM
Not a good sign at all. It sounds like you are going to either rebuild it or replace it.
