Transmission swap
155,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
STEVE BEAMON
I want to know if a 2004 transmission will fit in a 1996.
Feb 28, 2021 at 7:47 PM
Good morning,
The 1996 has a 4 speed transmission and 2004 has a 5 speed transmission.
The simple answer is no, it will not work due to the controls.
You will need the correct transmission. You can go to www.car-part.com and check in your area.
You need a 4R70 for your 19. I attached a YouTube video for you below for the procedure.
https://www.youtube.com/watch?v=7fp8sPhlIOg
Feb 28, 2021 at 8:27 PM
