My car doesn't move while on drive but spins forward on all gear while jacked up.
Mar 8, 2023 at 8:35 AM
✓Experienced Mechanic
This can be because the internal speed sensor has gone out, but we should run the codes to see, also please check the fluid level. Here are two guides to help get us started on fixing the problem. I have included instructions in the images below for your car.
