Transmission
17,300 MILES • 2.6L • V6 • 2WD • AUTOMATIC
MRJONES2819
Truck will go in drive and reverse l1 and l2. In drive it will not go over 30 mph. In l2 will not go over 40 mph. Does this mean my transmission is bad or is there something else I should look at?
Dec 12, 2018 at 10:23 PM
Good morning,
Does the transmission feel like it is shifting or is the engine running at high engine RPM?
How long since the transmission has been serviced?
Is there any codes stored for the system?
Dec 12, 2018 at 10:26 PM
MRJONES2819
The rpm goes high if it goes above 40 mph. Do not know about codes and has never been service. Do you think it could be my catalytic converter?
Dec 12, 2018 at 10:40 PM
No, this sounds like a transmission issue from your description. Take it to a parts store and see if there are any codes stored.
I would start by changing the oil/filter in the transmission and inspect for any debris in the pan.
Dec 12, 2018 at 10:42 PM
MRJONES2819
Okay, thanks. If the strainer has debris in it will that cause it not to accelerate?
Dec 12, 2018 at 10:44 PM
It is possible but if you find debris, then the next step is to have someone check this to confirm. Have them road test the truck to confirm your issue.
Dec 12, 2018 at 10:59 PM
