Possible limp mode and codes P0755, P1760, P2135
120 MILES • 2.3L • 6 CYL • 2WD • AUTOMATIC
AKRAM.KAWAMLEH
  • 5 POSTS
My car is Samsung sm7 2006 (Nissan Teana j31). My car only drives in second gear and reverse gear. which i think it is in a limp mode.
i got the following trouble codes :
P0755
P1760
P2135
please i need your help!
Mar 19, 2019 at 10:25 PM
  • 55,709 POSTS
The last code is for the throttle actuator which can cause the problem of limp mode. Lets follow this guide to help fix the problem and then clear the codes to see what happens.
https://www.2carpros.com/articles/reduced-power-limp-mode
and
https://youtu.be/ahK_eucFi-k
Mar 21, 2019 at 4:52 AM
AKRAM.KAWAMLEH
  • 5 POSTS
I cleaned the throttle actuater and cleared the code but still the same problem still doesnt shift only stuck at 2nd gear , I got t2 codes
P0755
P1760
Please I need your help sir
Mar 21, 2019 at 9:03 PM
  • 55,709 POSTS
Okay, got one code gone, lets replace the valve body with a rebuilt unit. this will take car of the remaining codes. here are directions below. Check out the diagrams (below). Please let us know what you find.
Mar 23, 2019 at 7:20 AM
AKRAM.KAWAMLEH
  • 5 POSTS
i got it fixed. i found that the connector and transmission plug (the one is connected to solenoids) was corroded and some wires were disconnected. i purchased a new plug and and wired it. All codes gone and the car is up and running like a champ.
Thank you so much.
Mar 24, 2019 at 8:43 PM
  • 55,709 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Mar 25, 2019 at 3:54 AM
AKRAM.KAWAMLEH
  • 5 POSTS
The car's transmission is working now, but every time i fired the car when it is cold the VDC light comes on, and it's like lost its power. I always turn the engine off then try to fire it again couple times then it drives.
I don't have this problem when the car is hot nor warm.
any ideas?
Thank you
Mar 25, 2019 at 5:46 PM
  • 55,709 POSTS
Please post your new question here, you must be logged in.
Cheers, Ken
Mar 26, 2019 at 5:36 AM
