Transmission removal
150 MILES • 4.6L • 4WD • AUTOMATIC
MARCUMMATTHEW66
  • 13 POSTS
Do I have to drop the transfer case when taking out the transmission?
Sep 8, 2020 at 10:58 PM
Good morning,
No, you do not but it would make it a lot easier for the procedure to drop it.
https://www.2carpros.com/articles/transmission-replacement-removal-manual
You would need a transmission jack that can support the combination to take it out together.
I posted a you tube video of removal of the transfer case for you.
https://www.youtube.com/watch?v=nki6EQw6zCQ
Mar 24, 2021 at 6:38 AM
MARCUMMATTHEW66
  • 13 POSTS
Thanks, but I got it with out taking it out.
Good deal. Heavy but can be done.
MARCUMMATTHEW66
  • 13 POSTS
Yeah, that's for sure.
LOL. I did that only 1 time. From there I took the extra times and dropped the case.
MARCUMMATTHEW66
  • 13 POSTS
How do you remove the flywheel and torque converter bolts?
There is a plate at the front most likely on the bottom of the housing. You can access them from there. Aside from the big mess you made leaving the converter in, once you remove the bolts for the converter and remove it, there will be 8 bolts for the flywheel.
If you pulled the transmission without disconnecting the torque converter, you most likely damaged the front seal. Make sure you replace it before installing it.
MARCUMMATTHEW66
  • 13 POSTS
How do you keep the torque converter from spinning? because I can get to the nuts but everything I do to keep it from spinning does not work.
Use an air ratchet. That should shock them loose.
MARCUMMATTHEW66
  • 13 POSTS
Don't have one. what else you got?
Then you need a flywheel tool. Go to a parts store and tell them you need a flywheel holder tool.
MARCUMMATTHEW66
  • 13 POSTS
How much does that run?
About $20.00 to $25.00.
You could also get someone to lock on to the bolt for the harmonic balancer and hold it while you try to loosen the nuts.
