Transmission not shifting properly
320,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
TODD EMPFIELD
Drive does not work to start off, but reverse, first, second work find. And when you get it up to speed drive works but the overdrive light comes on shift it back down.
Jan 9, 2019 at 1:07 AM
  • 55,649 POSTS
It sounds like you have a partial plugged catalytic converter which will lower vacuum and cause the transmission is shift late. Here is a guide that will help confirm the issue:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Jan 10, 2019 at 4:30 AM
