Transmission intermittently disengages
100,000 MILES • 7.5L • V8 • 4WD • AUTOMATIC
DBAIER
Transmission intermittently disengages at highway speed then drops back in with a bang. Speedometer also jumps over 40 mph. Related?
Feb 6, 2020 at 6:33 PM
Good morning,
Did you check the fluid? A low fluid level or a clogged filter would cause this issue. I would start by changing the fluid and the filter.
Are there any codes set?
Hopefully changing the fluid and filter will resolve the issue. This transmission did not have a good reputation. It had a high failure rate.
Feb 6, 2020 at 9:34 PM
