Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Oldsmobile
Ciera
Drivetrain
Transmission
Symptoms
Engage
transmission not working properly
1992 OLDSMOBILE CIERA
266,000 MILES • 6 CYL • AUTOMATIC
TERESA BARTLETT
MEMBER
1 POST
i went to leave i put my car in reverse and it wouldn't move and will not go into gear or anything now.
Oct 1, 2020 at 1:58 AM
Experienced Mechanic
Good afternoon,
Did you check the fluid level? Make sure it is at the proper level.
I would also consider changing the fluid and filter. The filter may be clogged.
Beyond that, it is internal such as the front pump or torque converter.
Oct 1, 2020 at 5:33 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
