transmission not working properly
266,000 MILES • 6 CYL • AUTOMATIC
TERESA BARTLETT
i went to leave i put my car in reverse and it wouldn't move and will not go into gear or anything now.
Oct 1, 2020 at 1:58 AM
Good afternoon,
Did you check the fluid level? Make sure it is at the proper level.
I would also consider changing the fluid and filter. The filter may be clogged.
Beyond that, it is internal such as the front pump or torque converter.
Oct 1, 2020 at 5:33 AM
