Transmission
196,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
CARINFO4GEORGE
Vehicle only running in first gear. Could transmission screen be a solution?
Oct 25, 2019 at 9:50 AM
I just want to confirm you have a CVT transmission because that is the only option I show but when you say it is stuck in first gear that indicates that you have a conventional transmission.
Do you know which you have? If not, can you just provide the last 8 digits of you VIN and I can look up how your vehicle is equipped. In fact, that may be best so we can get this right quicker. Thanks
Here is a document that explains CVT if you are not sure, but again if you send me your VIN I can make sure to give you the best info.
Oct 26, 2019 at 9:29 AM
