My transmission has pink milky fluid. What do I do?
150,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
DARRELLHINKLE1980
Apr 27, 2018 at 6:19 PM
SQM
  • 6,383 POSTS
It sounds like you have coolant in the transmission fluid.
The radiator has built in lines for transmission cooling. If you have a leak in one of the lines inside the radiator it could result in coolant and transmission fluid mix.
This will require replacement of radiator and flushing of both transmission fluid and coolant.
Here are couple of helpful articles:
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
Oct 25, 2021 at 3:29 AM
