It was driving fine,stopped at stop sign, went to go and had no gears.
Mar 21, 2018 at 2:14 AM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
Check the transmission fluid level and make sure the shifter lever on the transmission moves when you move the shifter. so you may need someone else to move the shifter while you look at the shift lever.
