transmission
166,121 MILES
BMAN1971
How do you change transmission shift solenoid, and is it located under a rubber boot,
Apr 13, 2013 at 8:13 AM
  • 75,988 POSTS
-See below
Apr 13, 2013 at 9:04 AM
  • 110,251 POSTS
It faces the front of the vehicle and is right above the transmission pan. It is bolted in place. Remove the wiring harness to it and then unbolt it. You may need to pry it apart, but be careful not to damage anything.
Apr 14, 2013 at 1:19 PM
