Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escape
Engine
Symptoms
Stall While Driving
Engines shuts off when I shift into gear
2013 FORD ESCAPE
98,875 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
1DRUM2
MEMBER
I have replaced the trans-axle solenoid body and it still shuts off. What would be next?
Jul 29, 2018 at 7:15 AM
Experienced Mechanic
Does the engine shut off? If so lets run the codes to see what come up which will lead us to the problem.
Cheers, Ken
Jul 31, 2018 at 5:45 AM
1DRUM2
MEMBER
Got the encoder reading it is P068A. All fuses are good and all connections are tightly fastened in ECM circuit and harness.
Aug 5, 2018 at 10:55 AM
This code of for the PCM power relay. It sounds like it is bad but to be sure lets run down this guide to test the relay the location is below.
Cheers, Ken
Images (Click to enlarge)
Aug 6, 2018 at 2:32 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine stalls while driving
Engine won't start
