Transmission seems to slip when it has warmed up?
175,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
ZDAWG1
Other than clogged filters or fluid change, what could cause this?
Jan 7, 2023 at 1:02 AM
BORIS K
  • 836 POSTS
Most common issues are low or bad transmission fluid or a blocked filter.
Damaged clutches usually cause burned residue in the transmission oil so when draining pay attention to the condition of the oil and any debris contained within.
A mechanical issue in the clutch bands will usually manifest itself in a slipping gear but not all gears.
A faulty valve body can also cause slipping gears as the it may bypass some of the hydraulic pressure required for proper engagement.
A good guide:
and
Cheers, Boris
Jan 7, 2023 at 5:34 PM
