Transmission will not go into gear
98 MILES • AUTOMATIC
A.CHISM
Once car is warm it will not go in gear.
May 5, 2018 at 11:30 PM
Good morning.
The first thing I would do is to change the oil/filter in the transmission.
a clogged filter will cause this issue. How long has it been since the transmission fluid has been changed?
If the filter is good, then you have an internal failure in the transmission.
May 5, 2018 at 11:55 PM
